iPhone icon that initiates an http request - how?
drivefast
Aug 16, 2007
this may be a really stupid question, since it's not about an iPhone application, but something way easier. is there any easy way that i can put an icon on my iPhone, like the calculator or the stocks icons, that would simply initiate an http request to a website, and display the page returned? sort of like a shortcut to safari. i am looking for a way to have this icon installed in a very easy way (sort of like for a totally non-technical person), so using the app installer and the app launcher is not an option. having that extra icon installed by the iTunes sync process would be the best. i have a feeling this should exist and i just cant find it - am i right?... thanks.
ps49556n
Jun 21, 2007
545
NYC
Not sure what you are asking here but to me it sounds like you want a safari shortcut? There already is one on the home screen....
drivefast
Aug 16, 2007
anybody else has an advice about how can an icon launch safari and make it navigate to an URL? thanks!
KennX
Aug 12, 2007
iPhone apper
This does exactly what you're looking for. Feed it a URL and an icon and it makes you a launcher.
Take care,
-KennX
drivefast
Aug 16, 2007
right on! too bad it doesn't work - at least for now. returns a 0 bytes file... :( but this is exactly what i need.
drivefast
Aug 16, 2007
on the "this" page (sic) you upload an image (.png) file that will be the icon, and you enter a caption (the text that shows underneath) and the URL where you want safari to take you. then press the "App me" button, and automagically a file download will start. that file download is the .app file that you have to load into your ipho. good luck.
Tinman
4,334
183
Aridzona
I was being literal. The post that I replied to had no link in it. He just wrote "This does exactly what you're looking for" without indicating what "this" was.
So when you replied to me I wondered how you got the URL (the URL for iPhone Apper).
Mike
drivefast
Aug 16, 2007
there's a great website out there that i use several times during a day: www.google.com ;) ;) and the key was in the subject of his message. i hear you, i was puzzled myself too at first.
