iPhone in Endless Reboot
Sep 29, 2007
348
My iPhone went into a endless reboot after downloading the applications TTR and Guitar Hero and Showtime. After they installed it went to the home screen and I got the spinning wheel and never went away after 20 mins. I turned off my phone and it still did it and would not leave after an hour and a half. I am contenplating a restore later tonight but wondering if anyone knows what to do.
I am on an AT&T 8GB iPhone JB 1.1.3 using MBP
6,682
49
Unfortunately, the only fix is to put the phone in DFU mode and then restore.
There is no way (that I know of, or have seen ) to stop the endless reboot otherwise.
cpolaris502
Nov 15, 2007
132
Rogers, MN
yes you can fix it. i did the exact same thing a few days ago. follow the directions in the following link and when you get the program up and running. find the applications folder in the phone and delete the ttr application.
http://www.ipodtouchfans.com/forums/showthread.php?t=15569
you will need the plugin that it says. like i said do everything it says, that is actually written for copying music from the phone to the computer.
so when you get to that part ignore it.
x666x
Jan 24, 2008
443
If you're on Mac, use Independence to get out of the boot loop, for PC use iBrickr .91
6,682
49
I had tried that when I got the endless reboot attempting to downgrade from 1.1.3 to 1.1.1 to jailbreak. I brickr couldn't stop it. I had to go back into DFU and restore to stock 1.1.3.
Of course, I believe it depends on what is causing the reboots, so where mine was probably an OS issue, his is probably an app issue.
