iPhone: Increase Time before Call Goes to Voicemail
kr3st
166
Winter Park / Orlando, FL
My iPhone always seems to jump to voicemail before I answer it. I need to increase the call forward delay. By increasing the delay before the call is transferred to voicemail, I have a better chance of grabbing it. As expected, the caller will hear an increased number of rings before being transferred.
This requires a little friendly hacking of your iPhone. Call your iPhone now from a different line to judge how long it takes to hit voicemail.
1. From the keypad dial the following: *#61#
2. Press the Call button
3. Write down your voicemail number. It's the number after "Forwards to"
4. From the keypad dial the following: *61*1VOICEMAILNUMBER*11*30# inserting your voicemail number where VOICEMAILNUMBER is. It should be 11 numbers.
(For example, if your voicemail number is 16787641111 then your command would be: *61*16787641111*11*30#)
30 is the length of time in the command above. 20 is the default. 30 is the max.
5. Press the Call button to send your command to the server
6. You should see the following:
Setting Activation Succeeded
Voice Call Forwarding
When Unanswered
7. Congrats. You are set! Call your iPhone again to see that it now takes longer to hit voicemail.
If you bugger you phone, don't blame me. Do this at your own risk. If you want to be super safe, you can call AT&T and they will do this for you as well.
kr3st
166
When Unanswered
Works for iPhone 3G and v1 iPhone.
Posted in both sections. Admin/Mod you can move these if I posted in the wrong section.
styfle
Mar 31, 2008
3,381
wow thanks
i would hit the button but its gone
im gonna try this out
will this work with other phones on AT&T as well?
jpm
Aug 5, 2007
212
Or you can just call customer service and ask for extending ringing. There was a thread on this from last year.
kr3st
166
If your anything like me, I try to stay away from talking with customer service people on the phone. If I can do it faster, why not?
behemot
Jul 23, 2008
is this only for AT&T or can i use this in Germany too?
kr3st
166
Not exactly sure, just do a test run with it?
Call your phone, time it.
Try this.
Call your phone again and time it. See if it works? Only thing I could think of, then you could confirm it for others as well.
dcom
Aug 7, 2007
1,421
Suwanee, GA
Very nice find. I think 25 seconds is a good compromise between the number of rings heard on the calling versus how long it takes to answer.
