iPhone installer help?
stampy
Dec 5, 2008
hi i bought my iPhone mid last year now all unlocked and had installer on it for 3rd party apps. i used the installer to get apps all the time and the installer had updates now and then to keep it up to date. all was fine until i updated it a couple of months ago and now my installer program on my iPhone just crashes and goes back to the iPhone display.
Is there anyway of rolling back the installer...or deleting it and starting fresh?
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
If you're on 2.whatever FW Installer is virtually useless. Cydia is where to be!
stampy
Dec 5, 2008
i have the 1st iPhone
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
The above applies to v1, too. Are you on pre 2.0 FW?
stampy
Dec 5, 2008
fw?meaning firmware.am on 1.1.1
stampy
Dec 5, 2008
and also then if installer is o good aymore( it used to be amazing) then how would i remove and put this new cydia on?
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
I don't know why you'd still want to be on such and old FW, 2.2 can be unlocked on v1's.
However, to fix your problem I believe you have to SSH into/var/mobile/Library/Installer and remove the remotepackage.plist. When Installer reboots it will build a new one.
stampy
Dec 5, 2008
well i moved house and no internet access so unable to update or keep in contact with they guy who i bough the phone off( who unlocked it aswell) bearing in mind i bought the iPhone before the release of it in the uk. so the only versions available was 1.1.1. i only just moved back to havig internet and im wanting to catch up on everything with my iPhone.
if you capable or know someoe who will help me update and sort my iPhone(installer or whatever then it would be much appriciated.
stampy
Dec 5, 2008
i will have A look at that website thanks. also then how can i get the SSH u was talking about. i deleted all the programs the guy gave me ages ago
stampy
Dec 5, 2008
i tryed to look for that file to remove and i can only get as far as library.theres no installer file there .. just localised and preferences
stampy
Dec 5, 2008
ok i wil download that and try and find that file you said to delete with that. but i tryed to find it with ibrick and found nothing
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
It might be in another location. Apple changed up the file locations so it might be somewhere else. You might have to do some research to find it.
stampy
Dec 5, 2008
ohh? ok thourght this might have been me researching:(
stampy
Dec 5, 2008
thats where it was. thanks a lot. now the installer is now working:D let me mess with this for a little while then i will want that new program and new FW. thanks a lot
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
Glad it worked out. If the same thing happens again you'll just have to repeat the process.
