iPhone is a piece of crap. iTunes doesn't even recognize my iPhone when plugged in
tamakin
Jun 30, 2007
404
doesn't even work. hooked it up to the computer, opened iTunes, no iPhone icon pops up, no startup message, nothing. what the hell
shift_2kmaxima
Jun 9, 2007
crap doesn't even work. hooked it up to the computer, opened iTunes, no iPhone icon pops up, no startup message, nothing. what the hell
upgrade your iTunes to 7.3
also upgrade your mac osx to version 10.4.10
and then if it doesn't work, you can say s***, but until then, lets be polite bout this piece of equipment,
i have owned mine since 6:05pm on friday, and i love every moment on it, i use it all the time, its the best thing i have owned in my life so far
and yeah EVERYTHING works on mine for me, so idk whats up with all these posts about iPhones not working and crap, its driving me crazy
later
lasquintanas
May 21, 2007
199
$100 says you haven't downloaded iTunes 7.3. Quit with the profanity, makes you look like an idiot.
wjp09
Feb 25, 2007
2,559
25
NJ
sorry you feel like that about the iPhone I love it and so many of us on this site love it to
tamakin
Jun 30, 2007
404
i have iTunes 7.3 installed. i have 10.4.10 installed and checked for new software update, im up to date. so now what? i'm supposed to plug the usb and its supposed to just guide me through right? how come it's not working? anybody?
JnC
Jun 17, 2007
333
How old is your computer? Does it have USB 2.0?
JnC
Jun 17, 2007
333
If iPhone doesn't appear in iTunes or you can't sync it...
The iPhone battery may need to be recharged. Use the cord and plug it into the wall adapter, not the powerbook.
If that doesn't work, disconnect any other USB devices from your laptop and connect the iPhone to a different USB port.
If that doesn't work, cycle power on the iPod. Press and hold the sleep/wake button on the top for a few seconds until a red slider appears, then drag the slider. The press and hold that button until the Apple logo appears.
If that doesn't work, restart your computer and reconnect the iPhone to your computer.
If that doesn't work, download and reinstall iTunes.
tamakin
Jun 30, 2007
404
how am i supposed to know if its fully charged? what color is the battery meter when its fully charged?
JnC
Jun 17, 2007
333
I don't think it has to be fully charged. But at least 50% should be good. It's green when charging.
Also make sure your powerbook is not running off of it's batteries during this, plug it in as well. Else the iPhone won't get any charge from the pbook.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
it'll have a power plug icon in the battery icon insteAd of the lightning bolt while its plugged in.
Have you ever synced an ipod before? If you haven't then you might want to get with a buddy that's done it. It can be confusing the first few times.
tamakin
Jun 30, 2007
404
:laugh2: I re-installed iTunes 7.3 and finally it worked! thanks guys.. please take down this thread
Dusty
11
I had the same problem for about 5 minutes when I got my iPhone last night. I have a 15 inch MBP and for some reason if I plugged it in to the USB port on the left side of computer it would only recognize it with iPhoto, once I plugged it into the USB slot on the right side, it was recognized in iTunes as well.
Not sure if the USB port on the left side is not USB 2.0. Can anyone elaborate?
Oh yeah and stop with the profanity, you look dumb doing that.
mav
May 9, 2007
356
Wow, you people flip out easily huh? You get a small problem and suddenly the iPhone is the biggest piece of crap out there. Funny.
PandaBear
Nov 14, 2008
My iPhone G3 is also a piece of crap.
1) No support for flac files, what you want to hear your music lossy? I don't. Apple Lossless is inferior to flac. Flac is THE standard for lossless audio.
2) No cut and paste. For word processing, emailing and quoting articles, etc., the iPhone is useless.
3) No support for Flash, so my iPhone is useless with streaming audio and video. Very limited amount of internet radio station with Tuner app. No local radio stations can be streamed via Tuner from their websites.
4) Very limited software for usage like Office Suites.
I guess the iPhone G3 is good for watching vids. Still, the iPhone will not support most of the common files. I know, I can convert them. But why should I have to just because Apple to totally stuck up?
Youngbinks
Jun 4, 2007
7,617
33
Atlanta, Georgia
All of the issues have been well discussed not only with the 3G but with the v1 as well. Maybe a bit more research prior to a $300 purchase and 2-year contract could do some good.
