iPhone keeps dying even when charging
Leina
Dec 19, 2014
I just got my iphone 6 3 weeks ago and now it's not charging. It died today and when I went to charge it, "This cable or accessory is not certified and may not work reliably with this iphone" keeps popping up. I eventually got it to charge but it won't go past 2%. Every time it gets to 2%, it goes back to 1%, then dies, then charges to 2%, then die again. How can I fix this?
Leina
Dec 19, 2014
Right now, wall. But I've also tried plugging it into my computer and the same thing happened
ivantwilliams
Jul 14, 2009
1,546
218
Maybe restart the device by holding the home button and power button till you see the Apple logo. Once done, try charging again.
Dec 15, 2008
5,386
340
27
Pensacola, FL
You stated that it gives you the message that it's not certified to work etc. But then you said it's the original. Did you get the iPhone from the store and it came with an Apple made cable?
Leina
Dec 19, 2014
Yeah the cable I'm using is the one that came with the phone from the Apple store, which is why I don't understand why I'm getting this message. I've tried restarting it by holding the home and power buttons but it didn't fix the problem.
ivantwilliams
Jul 14, 2009
1,546
218
Hmm, you might have to borrow a friends cable and see what it does. Or take it to an Apple shop.
Rafagon
Dec 7, 2011
7,566
1,254
44
Miami, Florida
It definitely sounds like a problem that your Apple Store would be happy to help with. I really recommend taking it back and asking for a replacement unit. Take it in. I'm sure they will want to test it, and when they see what's going on, they'll take care of you.
Leina
Dec 19, 2014
I ended up taking it to the Apple Store and turned out the problem was with the cord so they replaced mine for free. Thanks everyone!
