iPhone Making Other Equipment Buzz
TheJimbo
Upstate NY
Anyone else have this problem after 1.1.1 update? Whenever my iPhone is near anything with a speaker, it causes the other device to make an intermittent buzzing sound. I first noticed it when I used my Bose Noise Cancelling headphones (buzzing in the headphones). Then on the speakers of my car stereo without the iPhone plugged into anything (just stting on the dash). Now as it sits next to my computer, there's an intermittent buzzing from the computer speakers - again, iPhone not hooked up to anything just sitting on the desk about a foot away.
Anyone else or just me?
Thx!
chris
Administrator
Administrator
Jun 10, 2006
11,812
1,778
Long Island, NY
This happened to me with the Treo and now the iPhone. No incoming SMS or phone call, yet the buzzing.
-Chris
TheJimbo
Upstate NY
Thanks guys, just wanted to check if it was my phone or others as well. Pressed for time today, couldn't do a search.
Dawgfan
Jul 27, 2007
347
Atlanta, GA
It's the phone's RF, or radio frequency I believe and if you have used a BB you are all to familiar with it.
Oh, and it isn't going away.. just imagine conference calls where everyone in the room or on the call has a BB, which does it quite frequently due to the frequent data interaction.
Best thing you can do is just give the phone some distance from speakers.
velvetropeparty
Jul 4, 2007
56
ALL GSM phones do this. Borrow a very common RAZR and put it near your computer. Send a text message to it, or place a call with the ringer on silent. Same thing... normal operation.
Zachary Vex
Jun 30, 2007
60
Minneapolis
Even when a cell phone isn't receiving a message or call, it will regularly "handshake" with the cell system, exchanging an electronic sort of "I'm here, are you here?"
TheJimbo
Upstate NY
Interesting......if it is a GSM thing, then that explains it as this is my first GSM phone. I only had CDMA previously and my Treo 700w never did this during the two years I had it.
Thanks all for the replies guys, much appreciated!
In my previous post I confirmed that even the 1.02 ver did this. However, the new 1.1.1 does it worse. With 1.02 I got the buzz when it was next to my phone, but I could put it right on top of my Bose Wave clock radio. Ver 1.1.1 buzzes anywhere within two feet of the Bose. Something is different.
scandalex
Sep 16, 2007
771
That would explain why I have never heard this buzzing before. The iPhone is my first GSM phone.
ahduke99
Jul 21, 2007
344
Charleston aka Chucktown, SC
yeah it happens wehn i try to use any kind of ipod accessory....thus making them almost useless because the song is drowned out by continual buzzing.
unitas
64
the software updates has nothing to do with it. The iPhone has bad radiation leaks. Keep it away for your brain, nuts, and your pacemaker.
Redfor
Jul 31, 2007
301
Fort Knox, KY area
This is normal for GSM phones, My Razor used to do it a lot as well, even if there was no incoming call or sms. You'lljust get used to keep the phone at least 4 or 5 feet away from stuff.
I realize that the update didn't cause the buzz, but it certainly did cause it to affect more electronic equipment. It is worse after the update.
kdarling
Jun 20, 2007
425
NJ, NC, CO
As an aside, a lot of people think the buzz is from a radio frequency harmonic. But it's not. It actually comes from the radio turning on and off at an audible rate.
GSM is based on all phones sharing radio frequencies. These frequencies are in the hundreds of MHz. Within any frequency, a phone will get to have a short transmission slice (varying in size) about 217 times a second. It sends something, then goes dead so other phones can send/receive.
So when in use, the transmitter turns on and off a couple hundred times a second. It's this burst of energy at a on/off rate low enough for humans to hear, that causes the buzz.
Here's a rough analogy:
Think of your home, with 60Hz AC power. You don't usually hear the 60 Hz on/off because most of your equipment is designed for surpressing it. That's the equivalent of your cell phone transmission frequency (which is actually in the MHz range). It doesn't bother you.
But let's say someone outside used a fast circuit breaker to turn off/on your entire house power. There'd be a power pulse each time they did it, and THAT power surge would cause a buzz in your neighbor's radios.
It's the transmitter on/off cycle that causes the buzz.
Jul 22, 2007
Your not losing your mind because my iPhone is worse now with the update. I'm glad you confirmed that I'm not alone. I'm sure some genius will tell us it is all in your mind but I'm 100% sure that after I updated the buzzing occurred more often. I use to be able to disable my email accounts and I would only occasionally get the buzzing as the phone switched cell towers. Now I get it constantly.
