iPhone Map problem
krisobe
Jul 20, 2007
233
I've been getting "Driving directions could not be received" after putting the start and end points. Can anyone please tell me what i'm doing wrong. BTW, im on 1.1.2 jailbreaked.
colombianito
Sep 12, 2007
166
im sure there is a mispelled word in your address... check it... the only times i have gotten that message that was the reason... map every address individually and if they both map, then try to get the directions... DO IT, don't assume you have them right, we all overlook things at times...
if that doesn't help, i dunno, but im sure that is the problem, like i said the only times (quite a few...) i have gotten that message was due to that... good luck.
krisobe
Jul 20, 2007
233
Is it necessary to put the comas, or do we just use spaces, like for example...
1234 Fairwood Dr Pasadena CA 91206
