iPhone message: This accessory is not made to work with iPhone
duckdogdrake
Aug 14, 2007
41
I keep getting the message, This Accessory is not made to work with iPhone. The screen also fades to white and it will not charge nor will my pc recognize it. Any suggestions will be greatly appreciated!
bfakhroo
Oct 2, 2007
132
are you using an ipod accessory? because not all ipod stuff work on the iPhone
bfakhroo
Oct 2, 2007
132
reboot your phone it might help
duckdogdrake
Aug 14, 2007
41
I tried but it didn't work. How do I remove the SIM card?
bfakhroo
Oct 2, 2007
132
you'll need a paper clip or any thing similar and just stick it into the small hole on the top of the iPhone and the sim tray will pop up
Are you sure it's the dock that came with the iPhone? Or an iPod dock? They look similar.
It's most likely some kind of USB error; I would recommend restoring and then trying to dock, but you can't due to your phone not be recognized by your PC.
Look around, there have been several threads on iPhones not be detected. At least one should help you solve the issue.
