iPhone mods
Radis
Jul 3, 2007
173
if you mod your iPhone can you delete your mods or not? like inventer is there a way to delete that?
You can 'delete' them in tow ways; it depends which one you're talking about.
To delete a single application, just go into 'Uninstall' under Installer and select the app you wish to remove.
Also, if you wish to remove every modification on your phone, you can perform a Restore in iTunes. It will completely wipe your Software.
- John
