iPhone name change
grandpamike
Jul 29, 2007
When I was setting up my iPhone, I misspelled how I wanted to identify the phone. It came out Mike's Iphonr not iPhone, is there a way to correct this ? Thanks in advance.
MacManiac102
Jun 23, 2007
69
When you plug your iPhone into iTunes, it should recognize it on the left hand bar underneath all your music and such. All you do is double click on the name and retype what you want.
w7ox
Jul 25, 2007
19
Maybe by going to Settings|General|Reset.
But you likely would lose all your data and might end up with an activation issue -- dunno. I'd call AT&T re activation loss before I did that.
Phil
MacManiac102
Jun 23, 2007
69
Phil
I know my stuff with Apple. Do what I said before you do anything else. There is no need to reset it nor call AT&T.
grandpamike
Jul 29, 2007
Thanks. Sometimes, the easiest way is the simplest.......
ssauradi
Oct 19, 2009
Thanks Buddy,
It Worked nicely,
can you tell me how to synch songs from iPhone to my desktop
also from desktop to iPhone without deleting any single file.
Auradi'sWorld
computerfox
Oct 2, 2009
3,550
New Jersey
www.abelgancsos.com
you can not sync songs from the phone, but you sync songs from iTunes by clicking sync. if you only want to have the songs (lets say from a friend) make sure you are manually managing the song files. besides that i wouldn't imagine any other way to do so.
ssauradi
Oct 19, 2009
I think there is an option to view the folders from iPhone by using win-Amp player, but we need an add-in which gives the folders view from iPhone in win-amp player,
Not sure but saw somewhere not tried with that.
If you know abt that can you tell me the details
Thanks & Regards,
Shiva Auradi ( Auradi'sWorld )
iNinja
Aug 8, 2008
3,986
20
UK
There are many 3rd party programs that allow you to pull media from the iPhone directly to your pc. I think i read your using a windows machine, so try the software below
http://www.i-funbox.com/
Krunk83
Jun 28, 2008
4,605
You actually can put music from your phone to iTunes by using senuti if you have a Mac. Doesn't work with a PC.
computerfox
Oct 2, 2009
3,550
New Jersey
www.abelgancsos.com
yes you both are correct. you can't directly take it off of the phone through iTunes, but that won't be syncing it because you would be only taking off the files via some third party software. what if you add more songs to the phone? you would have to take off the files again so it won't be syncing.
Krunk83
Jun 28, 2008
4,605
Once you use senuti it automatically puts the music into your iTunes and then it is in there for good. If you add music to your iPhone besides purchasing them (purchased music transfers to iTunes from phone if bought on the phone) just use senuti again and those too will go into iTunes. It's that simple.
ssauradi
Oct 19, 2009
Thanks buddy It works fine,
Thanks a Lot
One more question from my side..
So any one tell me whether iPhone is a touch screen mobile phone, or touch sensitivity mobile phone.
I used windows and iPhone 3g both, in windows I can use stylus any where like select copy paste etc.
Where as in iPhone I can't use I have to touch my finger on the application icon It self, also no redo or undo exist.
I believe it just a Touch sensitivity based mobile, where it doesn't belongs to touch screen mobile.
Krunk83
Jun 28, 2008
4,605
Thanks a Lot
It is a touch sensitive(heat) phone and a stylus will not work. Has to be a finger or something that has heat. There is an undo, if you want to undo something just shake the phone and a box will pop up. This works for text, copy/paste, etc.
ssauradi
Oct 19, 2009
Waw its very interesting, Thanks got it......
I love iPhone........:cool:
