iPhone newbie! please help!
ezer88
Jan 9, 2008
9
hey, i bought an iPhone last month, but right now, i only used it for SMS and call people. that;s it!
i have 3 question :
1. i just download a ringtones and icon from zedge.net, but how do i put it on my iPhone? i used iTunes but i only can play the ringtones as like a music, please help!
2. how do i put my PC wallpaper to my iPhone?
3. i just installed a dictionaries, but i never seen it on my iPhone.
please advice
sorry for my bad english
KNK
Jul 22, 2007
2,391
Stevenson Ranch
i have 3 question :
please advice
Welcome to the forum.
I will give you a link for the photos in a minute and 33 seconds.
Here is how to do the ringtones:
1. Find a song you want to use as a ringtone.
2. Use whatever program you use to "clip" a section under 30 seconds long.(Audacity is a Freeware Program)
3. Double click the shortened file and it will go into the "Music" section of iTunes and it will start to play.
4. Right click on the file and choose the "Convert to AAC" from the drop down menu.
5. You will now have two of the same files in the iTunes Music Playlist.
6. Right click on one of the two and choose "show in (to locate the file) explorer."
7. Right click on the song with the m4a to m4r extension. You can delete the other one from that folder. If you don't see the file extension then you need to open your Explorer (myComputer) go to tools/folder options/view then go and make sure you have un-checked next to "Hide extensions for known file types".
8. Change the extension from m4a to m4r.
9 Go to iTunes and delete BOTH of the files from the playlist. Just make sure you click on "keep files."
10. Now go back to the folder you have the m4r file and double click it. It should go into the "ringtone folder" of iTunes.
11. Connect your iPhone, click on the "ringtone" tab and the song you need will be on the list. Check the check box and press the apply button lower right
ezer88
Jan 9, 2008
9
wow! awesome...thank you so much! i really appreciated it!
can i download songs from iPhone? i sync it but suddenly i change my mind and i don't want to put that song to my iPhone, how do i delete it?
and i download also for the SMS thing? is it the same steps for ringtones?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
The sms will require jailbreaking.
To not have a song on the iPhone, in iTunes where you song is just unCheck it.
In the summary panel when your phone is docked, under summary just check the box "sync checked only songs and video?
ezer88
Jan 9, 2008
9
how come the songs wont transfer to my iPhone, it said that
"songs" was not copied to iPhone because it cant be played in this iPhone"
what should i do?
ezer88
Jan 9, 2008
9
what do you mean by jailbreaking? do you have the thread?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
what should i do?
It means there is something wrong with the song file and will not play in the iPhone.
ezer88
Jan 9, 2008
9
my iPhone is already jailbreak. i bought it from ebay, unlocked 1.1.1
i already have "installer" icon on my iPhone. but how do i change the SMS sound?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Look for member Griffanaz for this, he has the howto for it. Or Maybe HAWK
