iPhone "no signal" after every call or text?
Jun 21, 2013
Has anyone else seen this issue ? When i 1st bought my iPhone 5 i couldnt load pics or videos on sms . Store said sim card was bad ... Replaced & has been fine since (4mnths ago)
Now almost after every call the signal drops to No Signal , & then re loads & does it after texting too
Sent using iCafe app
ed2438
Apr 9, 2010
365
25
El Paso, TX
I would take it to an Apple store. They will more than likely replace it. Seems like it could be an issue with the internal antenna. Have you done a restore on it to make sure it's not a software issue?
Sent from my iPhone 5 using Tapatalk
