iPhone not charging with computer
ajkennedy
Nov 17, 2008
Hi,
suddenly my iPhone stopped charging through computer (the same was working fine till yesterday). But it is charging with the power adaptor.
Iam using 2G and 2.2 is my version.
Can someone help me on this.
6,682
49
How are you using 2.2 firmware? It's not out yet. 2.1 is currently the latest.
If your phone is not charging from the PC, try a different (preferably Apple made) cable.
raxelsen
Nov 16, 2008
42
Dublin
www.moneymadeonline.ws
I guess the cable works as long as you used the same cable when you charged with the power adapter, so I guess it might be your USB hardware or driver?
Try using another USB port, or see if the USB port works with some other equipment.
ajkennedy
Nov 17, 2008
Sorry, iam using 2.1 not 2.2.
Checked the cable and system both are fine(tested with my friend iPhone).
I was using Apple cable only.
Regards,
John.
6,682
49
So does the phone charge from the same cable connected to the wall charger? If so, I would try to reinstall iTunes latest version and test.
What operating system are you using? Windows XP, VIsta, MAC?
If a windows system, does the system make the "hardware Connected" tone notification when you plug in your phone? Does a window open up asking what you would like to do with "Apple iPhone Camera" pictures? if all that is happening, then it's something in iTunes. If not, then there might be a problem with the phone's connector. Make sure that it is debris free. No lint or anything. Blow it out with straw or something. don't use canned air. It could blow crap up into the phone.
If none of that works, the last suggestion is to test on somone elses PC to see if it is recognized. If not, take it to Apple.
