iPhone not Syncing with Outlook 2003
paigeboyer
Jul 7, 2007
Help! I spent an hour with Apple and 3 hours with microsoft and no one can tell me why my iPhone won't sync with outlook.
I bought 2 iPhones and have Outlook 2003 on 2 different computers. One works fine. The other will not sync (newer dell computer). The com add ins keeps unchecking the iTunes sync box or it gives a fatal error message and puts the iTunes sync com in the disabled area.
I have removed iTunes and Outook twice and reloaded and still the same problem. I finally moved my contacts to the windows address book and set up mail manually, but I don't have any options for the calendar. This is really frustrating, especially when it works fine on the other computer, which is an older HP.
Both are operating Windows XP, same iTunes, same Outlook, same viris/spam...Help, I think I am going crazy!
thedwp
Jun 24, 2007
271
The quickest way to fix your problem is to go to the Apple store and by a MAC. --Problem Solved-- ;)
paigeboyer
Jul 7, 2007
I agree, but....
Yeah, I did order a Mac Laptop, should be here by Tuesday, but still think the product should work as advertised....and why does it work on one and not the other? Now it is a mission to find out what is going on!
Popdevil
Jul 2, 2007
254
I had the same issue. You need to go to help/about office/disabled. Enable and the check box will stay.
JnC
Jun 17, 2007
333
A suggestion was made in another thread to add iTunes to the DEP.
Jul 19, 2007
Outlook 2003 definitely not syncing to my i Phone
It appears that I suffering from the same problem as many. From the hour on the phone, all the way to the error messages.
Have you found any solutions at all? I am completely stuck and getting rather frustrated.
If anyone can please help me I would be eternally grateful :laugh2:
Hippie Chick
bigmac
Jul 13, 2007
110
Los Angeles
any luck getting outlook to sync calendars? This very fustrating!:mad:
In2Deep
Jul 4, 2007
37
I'm on a new Dell computer as well, XP Pro, Outlook 2003, iTunes 7.3.1.3, Norton Antiviruns... no problems. Syncs every time.
gkreed
Jul 17, 2007
45
Any solutions yet? I am having the same problem. WIndows XP, Outlook, and my calendar will not sync. The contacts are syncing fine. I have checked the COM ADD-ins and the disabled. I have all the up to date softwares.
Any advice?
Thanks!
impaler
Apr 28, 2007
522
I'm having similar issues...Outlook 2003, XP Pro, iTunes 7.3.1.3, and contacts sync beautifully but no dice on the calendar. Anyone had success here?
JnC
Jun 17, 2007
333
iTunes 7.3.2
Folks, there was a new version of iTunes that just came out today: 7.3.2. It's supposed to fix some bugs. Install it and see if it addresses any of your sync issues with outlook.
gkreed
Jul 17, 2007
45
Worked for me! Hope it works for you!
impaler
Apr 28, 2007
522
Oh, I really hope it works! Glad it worked for a few. This is the only point of true annoyance I have with my awesome iPhone.
Jun 5, 2010
I hear your frustration! have not been able to sync my iPhone #G with my Outlook 2003 ever since I upgraded to the latest version of iTunes. I have spent about 5 hours with Apple support folks and as many hours with my company IT folks. The first fix, to upgrade to service pack 3 (from 2) did not fix the problem. I've also checked that the appropriate DLL files are installed. I've reinstalled iTunes, and reset the sync history. Still, I am back in prehistoric land printing my calendar on paper so that I don't end up late to meetings because the information is on my phone etc. I have been so busy that I can't get back to try something else very quickly and so it has been months. I hope someone has a solution! It makes me want to decline updates as something always gets messed-up when new software is introduced...
Jun 5, 2010
Buying new equipment is NOT the answer.
Exactly what I did!:laugh2:
Easy to say but I don't think buying a new computer addresses the fact that I was a very happy camper with my iPhone and PC communicating successfuly for the 17 months I've had my iPhone. I did not change my PC...what changed is iTunes! I'm all for progress but if it takes you back in time, what is the point?
GailLA
Nov 13, 2007
265
35
Northern IL
Lisa, what version of windows do you have? If it is Windows 7, do you have the 64-bit version? You are not the only one who had Outlook sync stop working for when iTunes 9.1 came out. Apple still doesn't admit there is a problem.
There is a work around if you don't mind setting up a calendar with google, syncing outlook to that and then syncing your google calendar to the phone. I prefer to do that anyway because then my calendar is available on the Web, my iPhone and my iPad.
Jun 5, 2010
Thanks for the tip...
However, I am on Windows XP. Do you know if the workaround will work with that version?
