iPhone not Syncing with Outlook 2003
zx11kllr
Jun 24, 2010
I fought this issue for nearly two months then finally did a complete os reinstall and it worked. As I was reinstalling all of my software I would sync after each one. Everything worked until I installed crystal reports. My pc is my work/fun machine and I did not need the software so everything was velvet. You may check all of your software.
Gazelle Software
Jun 6, 2011
I recently had problems syncing my calendar between Outlook 2003 on Windows XP and my iPhone. I solved it by trying whole bunch of things, but here's the key steps.
1) try doing what Apple says http://support.apple.com/kb/HT1692, especially about resetting sync history
2) if that doesn't work (it didn't for me) another forum suggested that a bad calendar entry was causing the problem. The only one that made sense was a calendar entry that someone else made for me and I accepted (an Outlook feature to "Invite Attendees"). I removed all of these, but it wasn't enough
3) I reset my sync history another time and bingo, everything was fine again.
Hope this helps/
