iPhone Notes Syncing Confirmed with Leopard
princess_80854
657
Based on Leopard's feature list, it looks as if notes syncing of some sort is finally coming to the iPhone.
Notes
Write handy notes you can access from anywhere — including graphics, colored text, and attachments. Group notes into folders or create Smart Mailboxes that automatically group them. Your notes folder acts like an email mailbox, so you can retrieve notes from any Mac or PC or access them from your iPhone.
mobilehavoc
Jul 12, 2007
156
This functionality will be coming to Windows via Outlook Notes syncing as well.
jrbnc
Sep 14, 2007
will the outlook notes sync be via iTunes usb cable sync like contacts and calendar are?
mobilehavoc
Jul 12, 2007
156
Yes, it'll be an additional item in the Info tab of iTunes when you sync your iPhone, along with the present Contacts and Calendars.
