iPhone on Slide for emergency problem?
rabski
May 19, 2009
I have recently made a reset on the whole iPhone.After it was finished i got the "Slide for Emergency" in various langauges. iTunes wont recognize it or my computer.How do I fix this? Computer does charge it though.
Its the 2g 8gb iPhone.
Here are SOME of the things I already tried:
1. recharged my battery
2. Reinstalled iTunes and AMD's
3. Restarted iPhone.
4. tried other usb slot
5. restarted my computer and reconnected my iPhone
nhl2007
May 19, 2009
hey man,
is your phone unlocked? eitherway try this. download the firmware u had in the iPhone before(this has to be the same firmware) and restore from iTunes. this shuld work. and make sure your sim is inside the phone.
good luck
rabski
May 19, 2009
my computer doesn't even recognize it,I went to a Att store and it didn't recognize it on their comp either.
Adam1389
Nov 20, 2008
588
Ilwaco, WA
The slide for emergency means your phone hasn't been activated yet. iTunes needs an internet connection to activate it.
If iTunes won't recognize it try restore or DFU mode. Search around for the instructions on here
prabhat
Oct 21, 2008
51
don't worry bro
u jst need to quickpwn again and finish all steps fully... u phone is not activated thats it...:cool:
5,578
Agree ^
Jailbreaking it with QuickPWN will activate it.
