iPhone PC Suite?
drumthrasher109
Jan 9, 2009
471
drumsplace.co.cc
Well, I REALLY need to use this program because it has a Notes feature which can send notes that I type on the computer into the Notes app on the iPhone, BUT, after I install it, it says this program needs to close.
http://ipcsuite.com
Maybe it's because I'm on Vista Home Premium SP2 Beta? I put it on a XP SP2 PC and a Vista Home Premium SP1 PC and they both worked just fine.
I'll try it on Windows 7 to see if it works. If it doesn't, I'll have to remove the service pack I guess...or just reinstall Windows from scratch as it is pretty much time to do so.
glsda
Oct 17, 2007
1,440
50
California
I believe pc suite works only on JB's iPhones correct?
