iPhone plan question
sjmejia408
Jul 30, 2007
35
I was wondering, if I removed my data plan + unlimited text which is 40 a month would I still be able to use wifi on my iPhone ? Thx
420greg
Jun 26, 2007
845
Orlando, Florida
Yes.
But I don't think AT&T will let you have an iPhone with out a data plan. They would have no way to provision it as all the iPhone plans contain unlimited data.
sjmejia408
Jul 30, 2007
35
Yes.
wat if I tell them I no longer have an iPhone? I only want to pay for minutes
tesh
Sep 24, 2007
54
they may charge a fee, considering that you are supposed to keep the plan for a contracted amount of time...
of course, you could say it broke and that you're using your gsm nokia that you had laying around (fib)
and that it's useless for you to have the plan...
sjmejia408
Jul 30, 2007
35
i want to get rid of the 40$ unlimited data plan.. i only want to use the iPhone for the minutes... i was wondering if i do that could i still use the wifi? or is att going to charge me for doing so... any feedback would b appreciated. thx
Youngbinks
Jun 4, 2007
7,617
32
Atlanta, Georgia
You have to keep the data plan unless you unlock your iPhone and go elsewhere for service. You can use all the wifi you want but you really don't have much of a choice as far as EDGE is concerned.
sjmejia408
Jul 30, 2007
35
so if i tell them i broke my iPhone n no longer need the data plan, and keep my minutes.. i can use the wifi with no extra cost?
Youngbinks
Jun 4, 2007
7,617
32
Atlanta, Georgia
Broke your phone? As in, now the EDGE isn't working? I doubt that will work but I actually haven't really heard of anyone trying. They can't really charge you for wifi because they have no control where you use it at. But they might deactivate your phone, but I'm really not sure how it would work.
sjmejia408
Jul 30, 2007
35
alright thx a lot.. i just don't want to disconnect the data plan and then getting billed 1000$ for internet use..
