iPhone problems ibrickr
dylan
Sep 11, 2007
Hello all new here!
I've just unlocked my iPhone using ibrickr but I keep getting this annoying pop up! "this device is not suitable for iPhone would like to switch to airoplane mode yes/no"
Tried restoring through iTunes and re jailbreaking with ibrickr no luck.
Thought it might be a wifi problem turned everything off pc/router no luck.
Has anyone had this problem?:mad:
coinstar99
Sep 6, 2007
221
If you have the newest version of iTunes, there is a compatibility issue with it and ibrickr. Check out iBrickr's website and see if they have this fixed yet. Good Luck
