iPhone problems need help...
isaingj
Dec 4, 2011
61
My iPhone 4S running iOS 6 is being wired lately. The problem is my iPhone 4S keeps rebooting by it self randomly and I don't why, it sometimes does this, it started a week ago. Does anyone know how to fix this and it's not jailbroken...
First try a hard reset. Press the home button and the lock button at the same time. Ignore the "slide to power off." Release both buttons when you see the Apple logo. No data will be lost; it's just a longer reboot.
If that doesn't help, restore the phone in iTunes.
Advin
Jan 17, 2013
Just use cable connect to your pc iTunes. Everything will be fine. (My last iPhone 4 is same problem, i do by this way) hope can help you.
Sent using iCafe app
