iPhone restore file
Jul 24, 2007
Does anyone know where the iPhone restore file gets stored when downloaded from iTunes?
skiz420
Jul 28, 2007
371
Boston
C:\Documents and Settings\********\Application Data\Apple Computer\iTunes\iPhone Software Updates
******** the user name of the login you are on... oh and you need to have hidden files showing... tools,folder options,view uncheck hide hidden folders
Jul 24, 2007
Sorry. I should have been more clear. Where is it stored on a mac?
skiz420
Jul 28, 2007
371
Boston
sorry... no idea on the mac... if i owned one i could help you out...
try searching for
iPhone1,1_1.0.2_1C28_Restore.ipsw
and if that doesn't work search for
*.ipsw
brinky
Jul 24, 2007
95
49
Atlanta, Ga
On a mac try your Library folder, iTunes, iPhone software updates.
