iPhone restore issue ?
Dec 14, 2007
PROBLEM;
i Believe I crashed my iPhone, it was working about two day ago (working great) in CANADA fido .. then as a dumb azz I was playing around. anyhow factory default Restore started and finish loading .... now all is locked and I am SOL.... I paid huge to get the phone setup last time ...
i dug up this information using search...
iPhone Restore File
Does anyone know where the iPhone restore file gets stored when downloaded from iTunes?
C:\Documents and Settings\********\Application Data\Apple Computer\iTunes\iPhone Software Updates
******** the user name of the login you are on... oh and you need to have hidden files showing... tools,folder options,view uncheck hide hidden folders
MY question is can I find a file on my computer and reload what was the best looking and setup iPhone in the world !.....
can I use a compputer restore ... computer restore of file(s) to use the SHIFT and RESTORE ... to bring back this iPhone ?
thanking you in advance for your help ....
Dec 14, 2007
Now when powered ON I get the iTunes logo and No SIM card
Chris716
Nov 29, 2007
807
IL
cant you just plug it into iTunes and click restore... if you cant get it working tell me ill buy it from you..
