iPhone scratch removal
gu014
Jul 28, 2007
Hello,
I realize this question has been posted previously, but i did not find a solid solution so i will ask again.
I have two minor scratches. One is directly to the left of the earpiece while the second is in the middle left. Like i said, both are relitively minor.
I was just wondering if anyone had any recommended products that i could try to remove these scratches with.
I unsuccessfuly attempted to exchange this at the Apple store. The gentlemen recommended against trying any of the creams that are used for 'ipod' scratch removal as they are too abrasive. I assume i would need to use some sort of glass polisher?
Any advise would be greatly appreciated.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
Hello,
Nothing has been posted about repairing scratches on this forum. You can send it back to Apple and let them replace the touchscreen, but it'll cost you $279.
r00t4rd3d
Jul 22, 2007
53
Use that cloth they give you in the iPhone box. Rub the piss outta the scratches with it. They will come out.
gadgetguy
Jun 20, 2007
84
Place a piece of wetted t-shirt over your index finger with a dab of toothpaste. It works on a million things & I have used it for years. Toothpaste is a mild abrasive!
iCop
Jul 7, 2007
87
Tucson, AZ.
And your face will smell minty fresh :laugh2:
kbhark
Jun 28, 2007
55
Would toothpaste really work on glass? I have a mild scratch on the bottom of my screen to the right of the home button. Is there any chance it will damage the screen?
Tinman
4,334
183
Aridzona
While the toothpaste trick does work, I would make sure to use plain white toothpaste (not a gel). I would also avoid some of the "whitening" types as these sometimes have more grit (you easily tell by, well, brushing your teeth with it!).
Mike
gadgetguy
Jun 20, 2007
84
The screen is tempered glass. The toothpaste will take the scratch out if it isn`t too deep. It will take a lot of polishing to get it out. When I was in the glass businesss we used cerium oxide & a buffing wheel to take out scratches on tempered glass.
iphonenut
May 17, 2007
373
is that found in plain white toothpaste or can i find this in another product? i, too have small scratches and would be interested in buffing them out.
ahduke99
Jul 21, 2007
344
Charleston aka Chucktown, SC
nothing could fix a scratch on glass. i got a bad one on mine, but luckily for me, the audio failed and i got a replacement with no scratch. you could say i lucked out.
gadgetguy
Jun 20, 2007
84
Cerium oxcide is a buffing compound & is not in any toothpaste. Use just plain white toothpaste & see if you can get the scratch out. Again, if its too deep you probably won`t get it all out. The toothpaste should also take out small scratches on any of the other surfaces on the iPhone also.
Mar 19, 2008
Quick Question
I was wondering, you said that the toothpaste trick will work with other surfaces of the iPhone. Is this correct? I have a few scratches on the back of my phone from my keys being in the same pocket as my phone and would like to have them removed. Thanks in advance for your help.
gadgetguy
Jun 20, 2007
84
If your scratches are not too deep, then the toothpaste should take them out. With a lot of rubbing, the deeper scratches will at least not look so bad. Good Luck!
Mar 19, 2008
Thank you. I test it out and hopefully get some before and after pictures for you guys..
Griffinaz
Oct 5, 2007
1,048
Phoenix, Arizona
The toothpaste trick is also fantastic for plastic car headlight covers that have been scratched over the years and removes the yellow "tarnish" that you get on clear plastics.
