iPhone Screenshot Thread
Discussion in 'Photo Sharing' started by AllanGT, Jul 19, 2007.
  1. fearofnormalcy
    fearofnormalcy Evangelist
    Jul 8, 2010
    118
    You need to install it first...it'll probably relocate itself to the proper spot once installed.
    Tap the .deb file, and select "Installer". It'll unzip and install the theme.
  2. snowtrooper1966
    Dec 10, 2009
    1,330
    I did try that earlier with no luck. Tried again after your post, and see there are errors....
  3. fearofnormalcy
    Jul 8, 2010
    118
    Try "Unarchive" first, then install. I forgot it's zipped...
  4. snowtrooper1966
    Dec 10, 2009
    1,330
    Same thing, errors.... :(
  5. ericsinsideout
    Jun 21, 2009
    367
    Anyone experience this with cydia yet?
    Sent using iCafe app
  6. Napoleon PhoneApart
    Jun 19, 2007
    4,396
  7. ericsinsideout
    Jun 21, 2009
    367
    no, that's just how it opens now. I'm debating on doing a restore and re jailbreaking it, but I really don't want to have to go through re installing everything again.
  8. Kadelic
    Kadelic Genius
    Jan 4, 2010
    1,614
    PKGBackup has worked quite well for me in the past for re-installing Cydia apps as well as their settings. Activator settings, iFile bookmarks, keyboard shortcuts, SBSettings data, SHSH blobs, web Clips, Cydia sources, Preference files, and Springboard layouts, etc. I don't know how much it costs these days, I think I paid $6 or so a few years ago, but it's worth it IMO. I don't recommend using it to restore Cydia app after a new iOS jailbreak but it's awesome for restores during the same JB cycle. YMMV.
  9. Europa
    Europa Moderator
    5,429
    Not personsally, but I've seen a bunch of screenshots of that. It's caused by installation of an incompatible app/tweak/theme. Did you install or update anything today? Try removing them in safe mode or with SSH, DiskAid, etc.
  10. ericsinsideout
    Jun 21, 2009
    367
    possibly, I think something had updated, and I was also test driving a new tweak that was from one of "those" repos, I guess I'll just have to bail on it and see if that makes a difference.
  11. ericsinsideout
    Jun 21, 2009
    367
    All better! Thanks Europa for the help! Not totally sure which package it was, I actually uninstalled a bunch that I didn't really use that I installed to try out (ie: livepapers and Deck). Less is more.
  12. Napoleon PhoneApart
    Jun 19, 2007
    4,396
    Also, stuff from "those" repos can be a bit iffy. :D
  13. ericsinsideout
    Jun 21, 2009
    367
    true story
  14. ericsinsideout
    Jun 21, 2009
    367
    Trying out a new theme
  15. Bennyboy
    Bennyboy Genius
    Jul 21, 2010
    1,756
  16. Bennyboy
    Bennyboy Genius
    Jul 21, 2010
    1,756
  17. Kadelic
    Kadelic Genius
    Jan 4, 2010
    1,614
    Who needs the stock wallpapers when you can take your own top notch pics? :)
  18. Bennyboy
    Bennyboy Genius
    Jul 21, 2010
    1,756
    Haha thanks buddy. It's crazy how this tiny camera can take such a crisp looking shot. I don't even edit my prints, I only edit for Instagram.
  19. besweeet
    besweeet Contributor
    Jun 7, 2009
    26
  20. Bennyboy
    Bennyboy Genius
    Jul 21, 2010
    1,756
    In a way I'm not, looking at the new features iOS 7 has, but I look at those icons and I shiver. I get it, functionality is way more important, but I'm too picky when it comes to design so who knows, I might jailbreak when it's time again.
Share This Page
