iPhone SIM card in your old phone
picmax
Jun 30, 2007
Have you tried to put your iPhone SIM card in your old ATT or Cingular phone? Will it work? I am mostly interested in knowing if it will work on Nokia E62.
Thanks.
Max
Mustang05
Jun 13, 2007
45
Yep. it works. and your old sim works in the iPhone.
picmax
Jun 30, 2007
Ok, so iPhone SIM card works on other ATT/Cingular phone. That's what I need to know because I will be keeping my E62. The E62 has so many features that iPhone doesn't have and probably won't ever have.
For the 2nd part, did you mean that after the activation, you can put any ATT/Cingular SIM card (assume it is still active) in the iPhone and was able to make/receive calls?
lucky8926
Jun 16, 2007
217
Central IL
Soooo I can use my old sim in the iPhone? Does the visual voicemail work?
MandyCh1ck
Jun 29, 2007
37
yes you can put it in an old Cingular/AT&T phone. No visual voicemail won't work because that is an iPhone feature.
lucky8926
Jun 16, 2007
217
Central IL
No, I don't have an iPhone yet. I want to know if I can put my current sim card in the iPhone and have it work. I really don't want to have to transfer all my contacts manually........
