iPhone sleeve case by Case Mate
charlesa
Nov 6, 2007
I have had bad luck wite the CaseMate sleeve case for iPhone. It covers part of the camera lens when it is put on the iPhone. I contacted AT&T where it was purchased and they said "The case might cover part of the lens if you push it down to far. This is within the tolerence of the manufacturer and there is nothing we can do about it." I received the same answer from the manufacturer. If I try to slide the case down to uncover the camera lens it has a loose fit and the iPhone slides out of the case. I really like the sleeve type case as it offers protection and you can still use the phone without opening or removing the case. I noticed that someone else gave a poor review on a canvas case from the same manufacturer. I guess they don't care about the customer. Does anybody have an answer as to where I can get a good slip case?
charlesa
Nov 6, 2007
had a similar problem with Case Mate's leather slipon. It covers the camera lens and gets loose and can slip off. Manufacturer will do nothing.
