iPhone slider! idea
H
Hayesimus
Guest
hey i just had a fun idea! can someone make an iPhone slider? like a little sideways iPhone. Either have an arrow on the screen just like the old slider. Or the homepage would work i guess. but then i'd probably want it to match my iPhone and it would get complicated with each mod i do. so just an arrow on the screen would be good.
H
Hayesimus
Guest
okay. i already made the button. now can somone tell me which file i need to replace. oh wait. i think i'm stupid.
holdon
yeah i was stupid. i figured it out lol. i'll go upload it on youtube so's you can see it :D
H
Hayesimus
Guest
meanvdub
Jul 28, 2007
What program are you using to slide all of your icons in that video?
Have a link to it?
It is Summerboard, you can get it via the Installer.app program that you can install via ibrickr (PC). First mod your phone with ibrickr, then use ibrickr to install the installer.app, then from your iPhone you can install lots of apps, including Summerboard.:cool:
H
Hayesimus
Guest
it is called summerboard. its an application for your springboard. i'd also recommend using an app called RSBT that will let you rearrange your icons and put ones you don't use regularly in a "third party" category. then you download summerboard and you can scroll down to see those extra icons. if you start seeing icons you don't want, just got back into rsbt and select that file and hit down until it is in the "hidden" category. i found both these apps on iBrickr. but i'm sure that you can search for them elsewhere
meanvdub
Jul 28, 2007
I thought it was Summerboard, just never saw it working. Do you guys that have it installed notice any drain on the battery? I know Dock drained mine pretty fast, just curious if this does the same.
H
Hayesimus
Guest
oh of that i'm not certain. i have had my iPhone on the dock for most of the day this weekend and that's when i downloaded it. i go to work tonight though. 12 hour shift and all. should be a good fieldtest on the battery life. i'll post in the morning at like 8am or so when i get off work unless someone else has already answered this question. regardless i'm sure there is at least a slight increase in battery use. but i don't know if it would be as bad as Dock.
The Apple
3,105
Indiana
glad to see everything came together well! looks greatimus!
H
Hayesimus
Guest
haha thanks! now if i could only figure out the slide to answer text. i keep screwin that one up. :S
