iPhone slot sticks out a little
BIGTIMEBALLER504
Jul 9, 2007
122
i have had my iPhone for a while and i just realized that the slot on top by the power on/off it sticks out a little and as much as i tried pushing it in it just wont go is this alright or is it suppose 2 be all the way in?
Ace4261991
Jun 18, 2007
530
if your talking about the 10th of a millimeter (i didn't measure) that the sim slot sticks out then i think theyre all like that as mine is. but if your talkin about sticking out more noticibly then what im talkin about then idk.
BIGTIMEBALLER504
Jul 9, 2007
122
not like all the way its just like very very litle u can just see the little outline aroudn the area
Ace4261991
Jun 18, 2007
530
yeah i think there all like that don't worry bout it
xSoNiCcRaCkErSx
Jun 30, 2007
226
take some pictures. they stick out a lil but not much to make it a big deal. try removing the sim slot with a paper clip to eject it then stick it back in, if its the same still then yours is probably the same as the rest of ours.
BIGTIMEBALLER504
Jul 9, 2007
122
im gona try 2 take it out i got a paper clip and bent it how do i use it in the slot?
spud2007
Jul 9, 2007
56
Just push straight down and give it a little push, if it doesn't pop out move the paper clip around until you feel you are touch the spring loaded pin. Straight down and you are good.
Ace4261991
Jun 18, 2007
530
Make sure you put the phone in the dock before trying to pop open the sim tray. It won't come out unless it's docked.
how is that? ive done it when it wasn't docked the first day i got it. and idk bout you but i wouldn't try taking out the SIM while the phone is on and running
jjvaldez
Jul 3, 2007
2,615
34
Salinas, Ca
yes make sure that the phone is backed up on iTunes before you do anything..
spud2007
Jul 9, 2007
56
It doesn't have to be docked.
