iPhone stuck in DFU mode, can't restore, error 28 on iTunes, HELP!
viliuset
Jan 16, 2011
I tried to upgrade the iOS from 4.1 to 4.2.1 and failed. Now I can't even turn the phone on or whatsoever. Can't restore the phone neither using redsn0w or other software.
Please help!
iphonewarrior
13,847
701
Error 28 indicates a Hardware error. Have you tried using a different USB? Are you running with the latest version of iTunes?
viliuset
Jan 16, 2011
just tried changing the cable and USB port. same error. and btw, the firmware is custom. If I try to restore with original firmware I get the error 28.
viliuset
Jan 16, 2011
ok, so far I am still on DFU loop, can't turn the phone on or see any iTunes or Apple logo on it.
Today I tried to restore it on another mac, but keep having the same errors like 1600. Tried to restore using official firmware also, but then got error 28.
any ideas anybody?
iphonewarrior
13,847
701
As I mentioned earlier on, Error 28 I a possible hardware error. I would personally suggest taking it into Apple for replacement.
28,365
5,506
If you can get past the error 28 and get to error 1600, I doubt it's hardware related. iREB doesn't work on the 3GS. Have you tried deleting the offical ipsw and downloading it again?
M
mafia_001
Guest
I thought the latest iReb could fix 16XX
viliuset
Jan 16, 2011
OK now. I fixed the problem by draining out the battery, don't get error 28 anymore. Now can't restore to custom either official firmware. Getting errors 16xx or something like 31xx. Tried on mac and windows using iReb. Didn't fix the problem.
