iPhone symbols
Moon37722
Jul 16, 2013
Hi. I've had a symbol on the top right of my screen right by the battery life info that I have no idea what to make of. Whatever it is appears to be draining my battery.
It's a padlock in a circle with an arrow at the end of it.
Please help.
Thanks a lot
Sent using iCafe app
Adriano73
Jan 17, 2012
337
77
UK
That won't be draining your battery that just shows the orientation of your screen is locked. The orientation won't change when you turn phone on its side. Double click home button and swipe left in multi tasking tray and the icon is there where you can switch it off.
Moon37722
Jul 16, 2013
Thank you so much for clearing that up! Appreciate the prompt, and clear, response. Have a great day
Feb 3, 2013
190
no need to worry at all for that lock icon. It's just the auto rotate is off. hehe.
AdamDaieh
Jan 17, 2013
141
California
The about comments are right, it doesn't affect the battery, it just a symbol indicating that your phone screen is lock vertically.
