iPhone transfers
riclee
Mar 4, 2009
How do I transfer music from my ipod to my iPhone?
kimo
Aug 7, 2007
169
Do you have the music that is on you ipod in iTunes? If so then use iTunes to load the tunes on your iPhone.
riclee
Mar 4, 2009
how do i use iTunes to transfer music to iPhone
BigCiX
Jul 11, 2008
1,445
Bakersfield, CA
hook up your iPhone while iTunes is open and it should sync. If now wait until iTunes recognizes your phone and then click the sync button.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
You follow the same procedure you would to sync an iPod.
When the iPhone is plugged into iTunes you should see it show up in the device manager. Choose the iPhone on the left hand side and you should see different tabs such as, "Info", "Music", "Video" and so on. Under these tabs you are given different options from which you can select media to sync.
