iPhone UK ac converter AMP fuse help!
Oct 10, 2007
hi everyone,
i have an iPhone unlocked and am using it in da uk.
its a real pain keeping my laptop on when im charging the iPhone and i have bought a converter so i can use the u.s version charger, i have two converters, one is a 13 amp fuse and the other is a 1 amp fuse.
the thing is i don't know what one to use and i don't want to blow my iPhone up.
any one have any suggestions on which fuse they use or know what one i shall use?
ive looked on google and cant seem to find anything.
regards
adeel.
baluvee
Oct 16, 2007
Hi
According to
Solio Solar Charger for Apple iPhone
http://store.everythingiPhone.com/content/accessories/5-58--612.htm
[FONT=Verdana, Arial, Sans-Serif]Specs
  • Rated Output: 4 -12V, 0 - 1 Amp (max)
  • Weight: 165 grams(5.8 ounces)
  • Internal Battery: Rechargeable 3.6 volts, 1600mAh lithium-ion
  • Wall Charger: 6-volt/300mAh
  • Dimensions (when closed): 120mm x 65mm x 34mm (approximately 4.7 inches x 2.5 inches x 1.4 inches)
  • Temperature Range: -20°C to 55°C
Hope this answers your question
Bala
[/FONT]
