iPhone volume booster?
__DorkSterr
Jan 20, 2008
90
I run a jailbroken iPhone 1.1.3, I was wondering if there is an App that boosts the volume of the speaker, (That actually works). I've tried these one but no luck...
Volume Fix 1.1.3
Volume Fix
Volume Boost (1.1.3)
Volume Boost
iAmp
AudioAmp
xcissexc
Aug 9, 2007
501
have you poke through the dust cover of the speaker? if you take a needle and poke through some of the holes where the speaker is it breaks the dust cover making the phone almost twice as loud
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
Volume Fix 1.1.3
Volume Fix
Volume Boost
iAmp
AudioAmp
None of those really work. The poke holes method is the best option. I haven't done it yet, but I'm contemplating.
NickT916
Jan 4, 2008
266
i did the hole poking, speaker is on the left side, not all holes can be pushed through, only maybe about 15 holes, you can go about 1/4 in safely
styfle
Mar 31, 2008
3,381
i think my phone is too new for the hole poke trick
