iPhone Web App Appearance?
reas0n
670
20
Stamford, CT
www.ohitsjustpete.com
Please Test on iPhone
Can anyone let me know if http://bobchatter.com/mini/ needs to be zoomed in? Is it very small? "Small like a thumbnail"....
demo account
login: myphone
pass: myphone
Thanks!
yes both log-in screen and the app need to be zoomed in...both very small
heres a screen shot of what i see on my phone
edit...its the same size for the log-in screen
lonestar19
Oct 26, 2007
9
Anyone know cause of Small thumbnail size Web App?
It is an extremely odd problem we have encountered with our chat service.
Any developers out there that could let us know if a similar problem has occurred and what the fix could be? All CSS and html is sized less than the needed dimensions for the iPhone. Tests performed on Safari pass, but with the iPhone Safari it is different.
Thanks in advance.
reas0n
670
20
Stamford, CT
Thanks in advance.
why not look at one of the source codes for the open source web apps or even a not so open source one....im sure you can see what its going wrong just by looking
lonestar19
Oct 26, 2007
9
it just a tiny bug...
Yeah have looked into other code but, it seems to be a really simple bug that can not be found... I think it is a div that was removed...
can you check the following link again and tell me if it looks actual size. "You need not login" http://bobchatter.com/mini/
Thanks!
lonestar19
Oct 26, 2007
9
This is one puzzling dev project, I have adjusted the tables with a fixed numbers... not sure if it works now.... but will keep on trying... it really is a cool app, just needs to adjust correctly.
reas0n
670
20
Stamford, CT
nope it didn't work...maybe you should make the design a bit smaller because when i double click to zoom it is too big for the iPhones screen only off by id say 50 pixels tho
