iPhone WiFi Question?
Limanto
Nov 9, 2011
Hey there
I lived inside campus and in my room the campus wifi is accesible. But i have my own internet wifi router, and everytime come back to my room, my iPhone doesn't want to connect to my router wifi but to campus wifi which is slow and gives you a lot of trouble. Is there any way that i can set my iPhone to default connect to my router wifi when detected?
Thanks again!
iphonewarrior
13,847
699
Hey there
Thanks again!
I've wanted something like this since owning my first iPhone. I live near someone who has a BTOpenzone internet connection, it's one of those hotspots that you can log into and pay for 30 mins etc. Since it's not password protected my iPhone, iPad, MBP connect to it automatically - it's very very annoying. I would love to see a menu built into iOS which enables the user to ignore specific WAN's.
coop1701
Jun 30, 2007
899
114
43
I can go into certain networks on my phone and tell it to ignore them.
Just choose it in the list and say Ignore this network.
iphonewarrior
13,847
699
If you go in to settings, WiFi and click on the hotspot there should be a button at the top that says "Forget this network".
Yep the forget network button forgets the network i.e you delete the network from your previously saved ones. There isn't a stock feature on iOS which enables the user to ignore networks.
Limanto
Nov 9, 2011
Unfortunately, although in my condition, i still sometime use my campus wifi when i am not at my home, so i cannot use the 'forget this network' because when i am on the class and need wifi i will use my campus wifi..
Lon
Jun 5, 2010
2,946
132
Alaska
It will still show up as an available network, it just won't automatically connect.
enjoylife1788
Jan 7, 2011
186
That's correct but what OP is trying to sag is that he wants to set priority in available networks. He wants to avoid re entering network key that he would have to after foegetting the network. Also, nowadays most uni's have long network keys.
