iPhone won't play music through dock connector
jpetticrew
Sep 25, 2007
88
Houston
I just bought this and when I hook my iPhone up to it via the iPod plug, it will charge the iPhone but will not play music through my car speakers. Any idea why?
steviep831
Jan 15, 2008
41
It was a serious question because it is probably the most talked about topic regarding the ipod. "How do I connect my ipod/iPhone to listen through car stereo speakers." I didn't see your link in the topic and just assumed you were trying to connect with your charging cables.
steviep831
Jan 15, 2008
41
Looking briefly at your link... it doesn't say anywhere that this is compatible with the iPhone. If that's the case you won't get any sound with these cables.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
It says it is for the iPod, also I would be afraid of the charger, the pod and the phone are differrent. The phone requires 5V, anything else will damage the battery. No ref to that in the link.
Kabeyun
Jan 10, 2007
665
Northeast US
What KNK said is true.
That notwithstanding, it looks like the iPod end of the cable cluster has a dock adapter, 2 RCA plugs, and a headphone plug. Assuming you wired the other end(s) properly to your Pioneer head unit, what happens when you put the headphone plug in the iPhone's headphone jack? (You may need an adapter to get the plug to fit in the iPhone's recessed jack.)
Does your head unit have an AUX IN port? If so, playing iPhone audio in the car is as simple as using a cable like this one. You can then use a separate car charger if you like.
Good luck.
-K
