iPhone won't play particular song, help
Jan 16, 2008
19
Louisiana
I have tried and tried to get my iPhone to play this one particular song, but it gets to the same point and makes a noise like the file is corrupt, and stops playing. If you scroll to a later part in the song, it will play, and the same thing happens again.
I have tried adding the song from multiple sources (including the cd!) to iTunes (on which it plays fine) but it always happens like this.
This is the ONLY song it does it with.
Any suggestions?!
Thanks,
Alissa
Jan 16, 2008
19
Louisiana
No, my sister has the cd and I used that to put it on my iTunes. When that file didn't work, I searched the internet and got 3 different files from 3 different locations, and all have the same problem. I think my iPhone just hates the particular song or something!:eek:
did you purchase from iTunes? Or download from someplace like limewire. You might just have a bad file.. Try deleted it and downloading it again.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
More than likely your search resulted in the same passed around file.
If the song is on iTunes, just buy it for .99
Jan 16, 2008
19
Louisiana
Thats what I thought too, but Im wondering why the original artists cd would have a corrupt file .... but it cant be corrupt because the file plays fine on iTunes and Ive just tried - it works fine on my nano too!
:sick:
phsycology
Dec 29, 2007
2,667
23
Bolton, United Kingdom
I have the same problem with a few of my songs, but I thought it was just because I had got it off Acquisition (P2P for mac similar to limewire) but if you're having the same problem...
My 1st gen nano did this with some songs so I just restored it and it was fine, but try converting the song I'm gonna try it now.
6,682
that almost sounds like you have a corrupt memory spot, not a corrupt song file. Especially if it's working in other places, but just not on the iPhone.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Hawk could be correct, you might have a problem spot in your memory. It wouldn't really make much sense for the song to work on your Nano and iTunes but not on the phone. But then again, what are the odds that the song is saved to the same spot in the memory each time? I would suggest buying it from iTunes for $0.99 and then see if it works.
Jan 16, 2008
19
Louisiana
Does iTunes provide a refund if it doesn't? I just really don't want to spend a dollar on a song that I already have 5 copies of! lol
I might call Apple tonight while I have nothing else to do :laugh2:
6,682
Make sure that if you are jailbroken or unlocked, not to mention it to the rep.
Sync ( check everything needed) before calling support. That way you aren't going to lose anything.
cdinca
Jul 4, 2007
397
did you already try converting to aac?
I had several files that I had encoded a while back in mp3 that my iPhone did not like. I converted to aac and they worked great.
