iPhone won't power off?
mcquaid1
Dec 8, 2007
134
Ireland
whenever i try to power off it just turns itself straight back on? its done this since before i restored it.....and updated from 1.1.1 to 1.1.4.....i try to turn it off normally...hold down 2 buttons, it gives me the option to power off and i slide it across....it turns off and then i see the Apple logo and its turning back on....any ideas?
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Well you shouldn't need to use the home button to power off, only if you want to do a soft reset by holding the top and home buttons. Try just holding the top button and turn it off. I bet that because you're holding both buttons it appears as if you're sliding to power off but by holding both buttons together you're just resetting the phone.
