iPhone won't ring
Fayewolf
Oct 10, 2007
62
I checked, the mute button on the side is not on. I can play music through speaker, when I have new sms, email it beeps, but ringtone is not working even when I use the stock ringtones! I installed sendsong, and used iPhonetonemaker, but tried to select stock ringtones and it just won't ring? I turned off and turn back on. I also tried to do a reset on phone (holding down power and home button, still no go!
Any ideas?
Nov 26, 2007
17
and i thank you for this post because i was having the same problem and had not a clue how to fix so in ending thank you for having that problem and telling me about that damn mute button
meiphones_brill
Nov 16, 2007
797
my iPhone doesn't ring either. this is because I have no friends.
geordisjd
2,442
Can you make phone calls and receive them, even if the phone doesn't ring? Does it vibrate? Do your ringtones play when you go in the settings/sounds?
Restore and reinstall your custom ringtones trough iTunes. No more of that hacking stuff.
petalmom
Jun 30, 2007
494
Try plugging and unplugging the headphones several times. That my clear the problem.
