iPhone won't sync apps
Koolbreeze
Jul 3, 2009
I keep getting a message when I sync my iPhone to my Mac. It says "iTunes cannot sync apps to the iPhone because the apps installed on the iPhone could not be determined". Why am I getting this message? So I can't sync my apps anymore?
T
technob
Guest
After restoring an iPod touch I had a similar problem. The problem was the date on my laptop was off once corrected everything worked fine.
manamaboy
Nov 24, 2008
Hope the Apple id u are using is the same one used for authorizing your iTunes on Mac?
