iPhone X random apps freezes
smithjackson
Aug 1, 2018
Hello Apple Community,
I have the iPhone from like 3 weeks but since then I have issues with most of the apps like Youtube, Snapchat, Siri and sometimes system apps but for now only twice. The others are very often. Well while using it sometimes the app just freezes then my phone freezes to or just the phone freezes! Its easy to fix, I just press the sleep/wake button and the colume down key for several times and the phone unfreezes. Sometimes when in settings for ringtones it just laggs. And the audio is very distorted but thats not that big of an issue. Could this be due to bad optimization of the apps or my phone is the problem? I am on the latest iOS version and I still experience it. It happens more often and often.
Ledsteplin
Oct 29, 2013
4,853
1,000
67
Florence, AL
Have you tried a hard reset?
• Quickly click and release the Volume Up button.
• Quickly click and release the Volume Down button.
• Click and hold the Side button.
• Keep holding the Side Button. The Slide to Power Off screen will appear; do not slide to power off. Continue to hold down the Side button until your screen goes black.
• The Apple logo will appear once your iPhone X begins to power back up.
• Release the Side Button once you see the Apple logo.
If that doesn't work, you might try Reset All Settings.
Go to Settings >General >Reset >Reset All Settings. This resets to default everything in Settings, including notifications, alerts, brightness, and clock settings like wake up alarms.
  • Like
Reactions: Sally123
