iPhoneBrowser = drag & drop ringtones +
Jul 23, 2007
205
I just found this cool piece of code and thought I'd share as I haven't seen a lot of talk about it in these parts.
iPhoneBrowser (1.4) will do just that from windows. I was able to merely drag and drop my previously created .mp3 ringtones (I use Audacity) into the iPhone (modded - FW1.0.2) directly and bam! Also says it will work with ROMs, ebooks and themes. It was really, really easy.
Hope this helps someone!
shyn320
Oct 18, 2007
26
how do i get this program? do u have a link where i can go and dl it?
thanks
Jul 23, 2007
205
follow the link in the first post, then hit the Download link.
shyn320
Oct 18, 2007
26
ok i added my old ringtones by dragging and dropping it ............. it shows up on my phone but it doesn't play any idea why that is?
Jul 23, 2007
205
Can you give some details? FW version? Is it jailbroken? details on ringtone? (do ringtones play on computer?)
shyn320
Oct 18, 2007
26
its 1.1.1 firmware the phone is jailbroken and the ringtones come up as a question mark on the left hand side like all the other ringtones
mernst
Jul 11, 2007
505
Gulfport, Ms
hmmmm I hope you didn't miss it up..... I believe he can help you out on this...
6,682
49
I'm on version 1.1.1 and it's jailbroken, and I can drag and drop any file I want to ringtones, but only the ones with the M4r file extension show up, and those still don't play.
Jul 23, 2007
205
The wiki linked above states the following.
UsageTo use, plug in your iPhone and run iPhoneBrowser. The screen should show up with a listing of your folders on the left. Once a folder is selected, the files show up on the upper right. Select a file to see the contents in the lower right. Right-click a file or group of files to see a menu describing your different options, Save As, Backup File, Restore File (not yet implemented), Replace File and Delete File. You can also drag and drop files or folders into the file window to upload them to that folder.
Make sure you have at least V7.3.1 of iTunes installed. If you still get errors, make sure you have the Manzana.dll and iTunesMobileDevice.dll in the same directory as iPhoneBrowser.exe.
Has this been verified by those having problems? The information doesn't state anything one way or the other about 1.1.1, I'm wondering if it is supported or not. On the issues link it shows a post with a problem with 1.1.1...
6,682
49
Yeah, I have everything setup correctly, and I can drag and drop files into my ringtones folder all day, but if they aren't a m4r extension, they won't even show on the iPhone, and if they are a m4r extension, they just won't play.
I ended up trying the new Alpha Ihphoneringtonemaker 1.4, and I was able to load all my old ringtones, plus a few new ones, and all but one work fine.
Not sure why the one isn't working, but I'm not going to worry about it right now.
