iPhoneinterface crashing
uPhone559
Jul 18, 2007
389
everything i type putfile anything, it crashes and reportrs to windows over and over - someone post there file please ;)
maybee mines bad?
bonnie5ive
Jul 19, 2007
thats what i thought but if you don't have the actual file you need in the main folder you're using, it wont recognize the command. Like a .png file for example, it would need to be in the folder with iPhoneinterface.exe to work...not just in a subfolder
UFGator
Jul 17, 2007
227
I had the same problem. It worked the first couple of times I did it, then it crashed every time. Don't know what the problem is...
alb0zf1n3st
Jul 2, 2007
624
Reboot your systems because I had that problem last night its crashing for god knows why what reasons...
Also when you edit a file and you decide to edit again and it crashes you need to do rmdir in front of the directory to the .png thats there now then putfile after that...
