iPhoneinterface.exe help
xyoung316x
Aug 13, 2007
9
I need help with iPhoneinterface program... When I open it up it just start up and then close... I can't get it to stay on so I can put in extensions or anything... Am I missing something?
TomTomTuning
Aug 10, 2007
196
Camp Hill, PA
To make the connection...
Go to start
Then run
Type cmd
In the prompt window
Type cd\ then hit enter
Type cd phonedmgthen hit enter
Type jailbreak then hit enter
Then it will ask you to push and hold the HOME & POWER button
keep holding it until the command prompt window does something, then let go. It will boot the phone.
Now this is where you can use "iPhoneinterface"
You only have to do Jailbreak once (unless you restore your phone)
If you already jaikbreak your phone, skip that step.
hoits2000
Mar 15, 2007
360
I haven't been able to use iPhoneinterface since the update either. It opens up and shuts right down. I have been using mazana, it works great!
TomTomTuning
Aug 10, 2007
196
Camp Hill, PA
I have only had my phone for a couple days.. so i have always had the new update.. (it updated the day i got it)
And "iPhoneinterface" has always worked for me.
Another thing you can try ManzanaUI
Its graphic interface (GUI), Download it.
Save it to the phonedmg folder
Go to start
Then run
Type cmd
Go to your phonedmg and click on the manzanaUI.exe Icon
This will open up a program with all the directory's
All you do is go to where you want to put the file
And drag and drop the file where they belong.
I can make a write up on it once i get home. (At work right now)
xyoung316x
Aug 13, 2007
9
I'm having a difficult time jailbreaking my phone... It just stuck on jailbreak reboot... I can't ever get pass it... I do lots of search and somewhere it did mention to uninstall itune... Is that true?
TomTomTuning
Aug 10, 2007
196
Camp Hill, PA
When do you let go of the HOME/POWER button?
I always let it go once i see activity in the command prompt window.
Now when the iPhone says connect to iTunes.
They stressed this in the guide i used, not sure if matters.
xyoung316x
Aug 13, 2007
9
I let go when the "connecting to Itune" sign comes up...
Casetay
Jul 29, 2007
45
you may need to download a newer version of iPhoneinterface i know when I started the version I had didn't work then I downloaded it again from a different source and newer version and it worked. Just a thought
