iPhoneRingMaker Help
HOTINPHX
Nov 11, 2007
I just updated to the new ringtone maker and when it syncs to my phone and sends the ringtone it does not show up in my ringtone list. I am not doing anything with iTunes.
Has anyone else had this problem? Looking for some help with this.
THX
abee02
Nov 11, 2007
im having this problem too and i still haven't' been able to figure out what the hell is wrong
jpm
Aug 5, 2007
212
Are you sure you have version 1.4.4? and iTunes 7.5?
abee02
Nov 11, 2007
yup yup yup, let me go double check *goes to check*... yup its those versions
6,682
49
I had 1.4.4 beta installed and it worked, but I had it check for updates, and it downgraded me to 1.3.4
Make sure that the right version is installed. Also, make sure that your ringtones are in the same folder as when you created them. If they have been moved, the program can still preview them, but will not upload them.
Try this if everything else it ok, but you're still having problems.
Browse to where the ringtone is, like you were making a new one, and just go through the steps. It should "create" the ringtone again and upload to your phone.
smokepsp32
Dec 2, 2007
45
Im using iPhone v1.0.2, and im using ibrickrv.91 for me to install ringtones...
Is this iPhoneringmaker is better compare to ibrickr?
