iPhoneringtone maker update soon!
greenjbhsd
Jul 13, 2007
571
From the site:
October 18, 2007
iPhoneRingToneMaker with Support for iPhone 1.1.1. coming soon
We are happy to announce the internal beta testing of iPhoneRingToneMaker with support for iPhone 1.1.1. Barring any unforeseen hurdles found while testing, a public beta will be released very shortly.
Good news for those that care!
Hi-Phone
Jul 5, 2007
104
curry
Oct 11, 2007
Just tried it and it worked PERFECTLY! :laugh2:
SkyyBoy
Jul 4, 2007
131
Hawaii
thanks for the update.
now that i can get installer on my iPhone via iBrickr AND also get ringtones via iPhoneRingtoneMaker, the upgrade to 1.1.1 will happen soon for me :cool:
cep
Jul 21, 2007
What worked? Is iPhoneringtonemaker available for 1.11, and functioning properly? I was awaiting a reply before updating to 1.11. I know that Apple will put out a new version of software to shut the door again on these apps.
iLLGT2
Jul 26, 2007
211
NY/LI
chris201
Oct 1, 2007
46
Wow man awesome, ive been waiting for this for a bit. But you emphasize read the warning first before using, it doesn't look threatening at all to me?
Thats what I was thinking. It is simply saying that if the song doesn't show resend it till it does show. If your songs disappear when you sync simply restore them with the magic button.
chris201
Oct 1, 2007
46
So I downloaded the program and the ring tone that I made will not play. I kept sending it like it said still won't play.
However the good news is that the ring tone was sent to the computer. So at least that has been accomplished.
All your normal ring tones still work so now worries.
Tinman
4,334
183
Aridzona
I tried this and found something interesting.
It doesn't use the typical methods used to get ringtones on 1.1.1 phones. It actually uses MP3 instead of M4A (though it still uses an mfr spoof file).
And while it did work for me, it killed two of my other already-working ringtones.
Here's how it writes to the plist:
<key>A27A.m4r</key>
<dict>
<key>GUID</key>
<string>773DD04888C34171A90CF6234147A3A4</string>
<key>Name</key>
<string>Let's do the Time Warp Again</string>
</dict>
<key>A27A.mp3</key>
<dict>
<key>GUID</key>
<key>Name</key>
</dict>
Not that it places the m4r file first. GUID string is also very long, and there is no Total Time key.
Edit: iPhoneRingtoneMaker removes the Total Time string from ALL entries in the plist, not just those it adds (it not only removed it from all my other custom ringtones, but also the ones I bought through iTunes).
Edit2: This release removed the sound effects options. As that is about all I use this app for anymore, looks like I will need to go back to the older version (that and the fact that it doesn't play nice with my other ringtones).
Mike
iLLGT2
Jul 26, 2007
211
NY/LI
I wonder if they are actually going on the phone but just not showing up and wasting space, hmm!
chris201
Oct 1, 2007
46
It shows the file in the sounds play list. But when you select the song in that play list to be your ring tone all that happens is your phone will vibrate there is no sound that is coming out. Seems to me that there is an issue that is not fixed yet.
To bad we can't let them know. I have tried to contact them and never get a response.
Joker
Aug 1, 2007
Cool...........I installed a ring tone and it work's perfect.Thank's
chris201
Oct 1, 2007
46
How many times did you have to send it to the phone? And did are you upgraded to 1.1.1 on your iPhone?
bigmac
Jul 13, 2007
110
Los Angeles
<key>A27A.m4r</key>
<dict>
<key>GUID</key>
<key>Name</key>
</dict>
<key>A27A.mp3</key>
<dict>
<key>GUID</key>
<key>Name</key>
</dict>
Mike
Can you translate to english?
curry
Oct 11, 2007
Ok so interesting thing happened...
After loading the ring tones and set one. I got a call from a friend the ring tone worked but when i answered the phone couldn't hear anything through the handset. Speaker phone works and my headphones worked...
I reset my phone and had my friend call back... same thing. Couldn't hear a thing
I changed my ring tone back to one of those regular ring tones and reset the phone. I can hear through the handset now but no more cool ringtones =/
greenjbhsd
Jul 13, 2007
571
Was not threatening to me either, but more that this was an alpha so while he put it out there it was clear how or how well it would work. I am still on 1.02 so don't want to upgrade till this is stable.
buttsecks
Oct 1, 2007
i downloaded the new update for ringtonemaker and did what they told me to but still cannot get any ringtones on my phone. don't know what im doing wrong. running on 1.1.1 and phone is jailbroken. going to try again when i get home i guess.
Alexander
Jun 28, 2007
1,724
Atlanta
I tried three different ringtones, and one actually worked! I've never used this app before, and I'm on a clean install of 1.1.1. Too bad I can't test it further due to the 3 time limitation. Trial limitation on Alpha software I'm testing? Lame.
rcrush
Jul 26, 2007
17
i Just downloaded the new version. Its working fine for me. The only weird thing is that when I sync iPhoneringtonemaker it deletes all the iTunes ringtones and vice versa. But it still works great.
