iPhoneringtone maker?
miketl
Oct 23, 2007
104
hey,
has anyone tried the iPhone ring tone maker from www.mobilitytoday.com i tried the trial version and it worked so easily. i said to myself finally i have custome rings.. so i decided to purchase the full version.. well after i purchased the full version the ring tones would not transfer to the iPhone. it tells me its complete and i need to turn the phone off and on.. but nothing
can anyone help?
scandalex
Sep 16, 2007
771
KNK
Jul 22, 2007
2,391
Stevenson Ranch
tell me of this free u speak of
If you are on 1.1.2 upgrade, Apple is allowing ringtones that you make yourself, or I have freely downloaded from several thread requests here on the forums.
Just drag and drop them into your iTunes folder and sync. All free. Do a search and you will find them.. I love the "24" ringtone the best.
Dec 17, 2007
19
how do u convert to aac?
Dec 17, 2007
19
While in iTunes just right click on the file you created and then click the ACC and follow where it is. and change to .mr4
Then you drag it to the iTunes ringtones
i have a pc it wont work can i send u a couple songs over aim and have u do it then send them back?
u'll get 2 cool points
thepunisher1991
Jul 30, 2007
72
hey,
can anyone help?
there is a much easier way to put custom ringtones and its free :laugh2:
