iPhones: Not amphibious...
natalie
86
Louisiana
www.myspace.com
So my iPhone went for a swim about 2 hrs ago. The music was still playing when I picked it up out of the water, and the touch screen worked but was slow.
Then seconds later it craps out. Screen goes frozen with an assortment of colorful lines.
I get a blower and blow the phone in all the little avalible holes... I tap on it a while and then my home screen comes back on.
The phone is able to turn on/off. The phone is keeping time, and I can even get the ipod to play with my headset plugged in. The phone also takes/keeps a charge. The only problem is the touch screen doesn't work.
Im wondering what I should do. Should I send it in to Apple and have then take a look at it?
The good thing about it, is that when it fell in the water, i had my iskin on. Which kept the water from getting into the headset hole and changing the color of the water tab.
Should I wait a couple days and see once its fully dry that the touch screen works?
Oh and btw.. im the new owner of a 16G as of 30min ago...
dturner
Dec 15, 2007
5,725
Louisville, Ky.
This same problem was posted awhile back. It was suggested that you put the phone in rice for a few days to let the moisture absorb out. Maybe someone will remember where the thread is located.
Just found the link. Check it out and good luck. Sorry to hear this.
6,682
49
I heard that you can put it in a bowl of dry rice, or something else like that and it will suck up the water if you let it sit for a couple days. Safest bet is let it sit as long as possible to ensure that it dries out. Keep it off till you are sure it's ok to turn it on.
natalie
86
Louisiana
www.myspace.com
I just called my phone and it rang perfectly, nice and loud... Just cant answer it.. lol
I turned it off and ill throw it in some rice this afternoon
Sorry to hear about that. I've heard about the rice things as well, and as odd as it seems, it's been reported to work. Best of luck with it.
If it doesn't work, send it to Apple.
- John
Buffy
Jan 20, 2008
2,216
Oh ouch...I cringed when I read the last sentence. I'm so sorry to hear that! :(
natalie
86
Louisiana
www.myspace.com
should i take the black back piece off to help with the drying? or will that void warranty?
also, does anyone know if theres a water indicator on the inside of the iPhone?
May 6, 2007
995
United States
According to the aforelinked post, someone noted that there is a water indicator at the bottom of the headphone jack. Whether or not this is true is not up to me, but it seems completely reasonable to me.
Indy
Jul 29, 2007
2,921
39
Sorry to hear about that, hope it starts working agian!
LoL to the rice thing. I can see people carrying around little zipbag baggies full of rice around in their pockets.:p
natalie
86
Louisiana
www.myspace.com
the water indicator thats at the bottom of the headphone jack didn't change color... it was protected by my iskin
kylegod
Jan 1, 2008
581
Bethlehem, Pa
don't take the back off. Some Apple stores check that. And if you send it to Apple theyll probably check too. My phone recently got wet and it worked but the sound died. I just took it to Apple for a replacement. didn't even bother to see if it would get dry, i wanted a new phone.
Jul 8, 2007
17
Rice?
Make sure to close the headphone jack off... a couple of people on here got a piece of rice wedged in the headphone jack and it swelled up from moisture and they couldn't get it out... also... HOW do people drop their iPhone in the toilet? Leave it out of the bathroom! PLEASE! :)
natalie
86
Louisiana
www.myspace.com
Mine fell in the tub, not the toilet
rennyn
errr not many phones are amphibious :)
Let it fully dry, put it in some rice, etc.
if it still does it, you can always try bringing it into the store and seeing what the "Genius" says.
